1st + 2nd Generation Hi-MD Volume Limitations?
Noted in each manual is the mW for each unit. The NH1 is and will be 5mW worldwide, the MZ-NH900/NH700 is 5mW in the US and I assume elsewhere - 3mW in Europe. The NHF800 is 3mW in Europe, and lists 5mW for US and Canada.
The MZ-DH10P will be 2.8mW in Europe, 5mW everywhere else. The MZ-RH10 will be 2.8mW in Europe, 5mW everywhere else. The MZ-RH910 will be 2.8mW in Europe, 5mW everywhere else. Since the MZ-EH930 seems to be Japanese only, it will 5mW.
  • 3 months later...
Updated for second generation - missing info about the RH710.
did you knew anything about killing the limitations from the volume?
we have in germany only 2.5 mw at the RH10...
the old servicemode don't work at the 2 generation.
may "you" help us with the rigth code?
greetz
minidiscforum.de
  • 3 months later...
My Hi-MD MZ-NH600 I bought cheap here in Sweden little over a week ago is said in the manual to have 3mW++3mW as European models should (and it has remote port+line in as European models have), yet the volume clearly increases all the way up to 30...? I thought all European models were crippled by making volume increase only work up to 25?
